Aceyone wrote:Strewth,that looked scary as Hell !
It's not as bad as it looks ... years ago I was lucky enough to get 90 minutes in the Seaking simulator at RNAS Culdrose and after a while the instructor chappy took me 'out to sea' and we came upon HMS Argus the Naval Supply vessel ...
It was rocking and pitching like a bronco but he showed me that you come alongside it - moving forward at the same speed - then you slide sideways till you are over it ... and you hover over it - still moving forward at the ships speed - its rising and falling beneath you - you are hovering just above the height of the top of its upward pitch ...then the magic bit ... he tells you to switch your eyes from the sea horizon to the ships superstructure in front of you ... and you wait a few seconds ... suddenly the ship has stopped pitching and is nearly still ... then the instructor says .. 'look at your hands' ...
What had happened was my brain had switched to the 'moving' horizon' and without knowing it I was controlling the helicopter in time with the pitch and roll so that eventually I was perfectly in tune with it and the ship was 'still' .... I was actually rising and falling in exactly the same rhythm.... then you just cut the throttle and land on ....
After that landing on a still oil rig was a piece of cake
It's an amazing experience - although I was sweating buckets at the end
