by Mackrick » Sun May 10, 2009 8:22 pm
The United States Air Force operates a modified NT-43A as a Radar Test Bed (RTB) with radar imaging gear on its nose and tail in radomes that are 9 feet long and over 6.5 feet in diameter.NT-43A, 73-1155 carries Boeing construction number 20702. It first flew on July 2, 1974 and was delivered to the Air Force ten days later. It served initially as a navigation trainer. It was retired from that role and delivered to AMARC on September 25, 1997. Identified as TH002, it was sealed with spraylat and sat in the desert sun for over two years. 73-1155 was selected for modification as the Radar Test Bed. It was pulled out of storage at AMARC and delivered to the Ogden Air Logistics Center (OO-ALC) at Hill Air Force Base, Utah for refurbishment on November 19, 1999.73-1155 was flown to an aircraft maintenance and modification facility at Goodyear, Arizona in March 2000 for the installation of the enormous radomes on its nose and tail.
DENMAR, Inc. was the prime contractor for the modification of the NT-43A. It is run by Denys Overholser, who wrote the "Echo 1" software used to evaluate the stealth characteristics of the Have Blue and F-117A Stealth Fighter. Under contract to DENMAR, Inc., the Lockheed Skunk Works designed and fabricated the mounts for radar installations on the nose and tail (see attachment) of the RTB at Air Force Plant 42 on the grounds of the Palmdale Airport in California. The mounts are made primarily of carbon epoxy honeycomb sandwich with machined aluminum fittings. They are 16.5 feet long and 6.2 feet in diameter. After conversion, it was rolled out on February 22, 2001. Its first flight in its new configuration was flown on March 21, 2001.
The flight operations contractor for the NT-43A is EG&G, operator of the "Janet Airlines" 737s and former T-43As that are used to transport workers to and from secure facilities in the Nellis AFB ranges. The lack of public sightings of the RTB suggests that the NT-43A operates from one of those secure facilities. It was sighted inside a hangar at Goodyear in December 2004, but otherwise it is rarely seen.
