Post your clipboard
Word games, jokes, funny Youtube clips and general joviality
Re: Post your clipboard
Postby Wedgy » Fri Mar 12, 2010 2:20 pm
7650
Postby Spitfire » Fri Mar 12, 2010 2:47 pm
The Financial Services Authority does not regulate Cash ISAs. :p
Postby Mackrick » Tue Feb 05, 2013 8:20 pm
Postby Mackrick » Wed Feb 06, 2013 6:45 pm
Postby Mackrick » Thu Feb 07, 2013 6:23 pm
Postby Mackrick » Sat Feb 09, 2013 7:09 pm
Postby Hihonyr8811 » Sun Feb 10, 2013 2:25 pm
53° 2′ 54.82″ N, 0° 38′ 48.99″ W
Postby Mackrick » Sun Feb 10, 2013 3:23 pm
There's been a few posts on the restoration so far ..worthe a read as things are on the move...
Parts needed following an engineering survey
No 2 fuel tank removal and inspections
New Electro-pneumatic rams
http://www.lincsaviation.co.uk/news/lancaster-nx611-return-to-flight/
Postby Mackrick » Sun Feb 17, 2013 11:50 am
pompadour
Postby Mackrick » Tue Feb 19, 2013 9:53 pm
Postby Gaz » Tue Feb 26, 2013 10:33 am
Pavlyuchenko
Postby Mackrick » Thu Feb 28, 2013 9:33 pm
Postby Dan4th » Thu Feb 28, 2013 9:47 pm
She is looking SUPERB!!!!!
Postby Mackrick » Fri Mar 01, 2013 7:08 pm
Postby Aceyone » Fri Mar 01, 2013 7:09 pm
Not meaning to sound daft but what is a clipboard and where is mine ?
Postby Mackrick » Fri Mar 01, 2013 7:11 pm
When you copy and paste something it stays on your clip board until its over written try pasting something as in control v or use the menu bar...
Postby Aceyone » Fri Mar 01, 2013 7:12 pm
Mackrick wrote:When you copy and paste something it stays on your clip board until its over written try pasting something as in control v or use the menu bar...
Oh right ,thanks !
Postby Sooty655 » Fri Mar 01, 2013 7:54 pm
Oh right ,thanks !
Well, go on then.
Postby Mayfly » Fri Mar 01, 2013 8:28 pm
Give him chance, it takes a while to work it out at his age!!! :p
Postby Aceyone » Fri Mar 01, 2013 8:52 pm
Work what out ?
Postby Nickolas » Fri Mar 01, 2013 8:54 pm
Make sure you are sitting comfortably.............
1. Push your bottom as near as possible
to the backrest. The distance from
the seat to the pedals is adjusted so
that your knee is slightly bent when the
clutch pedals is fully depressed.
2. Rest your shoulders as closely as
possible on the backrest. Set the
backrest tilt so that the steering
wheel is easy to reach with slightly bent
elbows. The shoulder contact
must be maintained when the
steering wheel is turned.
3. Set the seat height as high as possible.
This ensures an unobstructed view
to all sides and all displays on the
instrument panel.
4. Set the seat cushion tilt so that it
is easy to fully depress the pedals.
The thighs should rest gently on
the seat cushion without exerting
pressure on it. Check the backrest
tilt before starting the engine.
5. Adjust the extendable seat cushion
so that the thighs rest on it to just
above the knee. A rule of thumb is that
there should be two to three fingers
clearance between the seat edge and the
hollow of the knee.
6. The lumbar support has been
adjusted correctly when the
lumbar part of the back is
supported in its natural shape.
7. The seat‘s side bolsters should fit so
snugly to the body that the upper body
is supported comfortably at the side
without being
restricted.
8. If possible, adjust the upper edge
of the headrest to the same height
as the top of the head. Tilt: The distance
to the head should be approx. 2 cm.
Postby RLN » Fri Mar 01, 2013 9:12 pm
Is that your clipboard, or advice to Acey? :ymdevil:
Postby Mackrick » Sat Mar 02, 2013 5:14 pm
6 Drakes Meadow
Postby Gaz » Sun Mar 17, 2013 4:57 pm
Postby Aceyone » Sun Mar 17, 2013 5:14 pm
Return to Fun and Games
