Well my friends, the day has now come when I post my
FINAL Report upon the
Restoration of Locomotive 34053 'Sir Keith Park', following the April 'Volunteer Session' at Herston Works. This Report is very 'Picture Heavy', as I have taken this last opportunity to try and capture as many 'close up' shots as I could, before
'Sir Keith Park' leaves Herston Works for Bridgnorth and the
Severn Valley Railway.This is planned for next Wednesday, 9th May. Should be quite a sight as the Locomotive makes its way, on the Low Loader, along the A351 road out of Swanage (especially through the winding part of the road at Corfe Castle!).
The format of this Report is slightly different to the previous ones but, hopefully, will split the photos up into manageable 'batches'. (The photos are mine, except where otherwise stated:
[SLL] or
[Roger Hughes]). There is quite a lot to take in this time, but I hope that you will be able to have the time to read it all. Thank you.
General:- The insulation to the Boiler and Firebox has been completed, all the casings fitted, painted and 'lined'.
- The fitting out of the Cab is more or less finished, with only some minor items left to fit (eg: the speedometer).
- The Sand Boxes which are fitted to each side of the Smokebox were in the process of being installed.
Here is the first batch of photos:
First, here is a Reminder of the condition that
'Sir Keith Park' was in when first delivered to Southern Locomotives Ltd in December 2000:
Full time Restoration Work on the Locomotive didn't really start until 2008, after
34070 'Manston' left Herston Works, following the completion of
her Restoration, in September that year.
Now......compare the above with these photos of the magnificent, Restored Locomotive:(a)
[Roger Hughes]
(b)
(c)
(d)
(e)
[Roger Hughes]
(f)
[SLL]
(g)
(h)
[Roger Hughes]
(i)
(j)
(k)
Roger Hughes]
(l)
(m)
Here are some more photos of the Restored Locomotive, but this time of the inside of the Cab, etc:
A general view of the Cab, taken from floor level:
PW thinking ahead to a 'Drive & Fire' later this year?:
The Steam Manifold:
Upper LHS of the Cab. Note the bracket for the speedometer, at the top of the photo:
Driver's side (LHS) of the Cab showng the Brake Ejector, Reverser handle and Regulator handle:
Close up of Brake Ejector, etc:
Bottom LHS of the Cab. Note the operating point (through the floor) for the LHS of the Rocking Grate:
Firebox Doors (Closed):
Firebox Doors (Open) [SLL]:
Upper RHS of the Cab:
Fireman's side (RHS) of the Cab showing the isolation valve to the 'Stone' Generator (located under the LHS rear of the Cab):
- Here is the 'Stone' Generator, underneath the Cab, that powers the elecrics.
Bottom RHS of the Cab. Note the operating handle (through the floor) for the Air Dampers:
Bottom RHS of the Cab showing the two sets of Steam and Water control valves to the Injectors (located under the RHS rear of the Cab)
- Here are the Injectors, underneath the Cab. Water is drawn from the Tender and 'injected' into the Boiler under steam pressure:
- The two copper feed water pipes, from the Injectors, that carry the water to the Boiler:
-The feed water pipes rise to run underneath the RHS Running Plate:
-The feed water pipes then rise through the Running Plate and connect to the individual Clack ('non-return') Valves on the Boiler. (Note the Mechanical Lubricators on the Running Plate, operated from the RH motion. There is a similar arrangement on the LHS of the Locomotive):
- A closer view of the Clack Valves. (Note the whistle, further back along the Boiler):
Now for my Report (and the pics) for the April 'Volunteer Session':
Thursday 26th April:- The copper 'Blower Ring' was being fabricated and trial fitted. This is fixed around the 'Lemaitre' Blast Pipe (fixed to the exhaust from the three Cylinders, at the bottom of the Smokebox).
- I carried out the final fixing of the Right Hand Smoke Deflector.
- Worked from inside the Smokebox, assisting with the fixing of the LHS and RHS Sand Boxes.
- Had the task of filling a 1.57 metre length of 50mm heavy gauge copper pipe (sealed with a plate at one end) with (special, fine) sand, in preparation for heating and bending. This, would you believe, took about an hour. The pipe had to be filled slowly to the top and then progressively tapped with a 'soft' hammer, all around the circumference (20mm at a time) in 300mm increments. Then returning to the bottom again (after each 300mm) refilling as necessary as the sand settled and compacted. Finally, a 'bung' was hammered into the open end.
The fabricated copper Blower Ring:
A close up, showing the holes drilled into the Blower Ring for the steam jets:
The Blower Ring, trial fitted to the 'Lemaitre' Blast Pipe [Roger Hughes]:
A view inside the Smokebox, showing all of the three Steam Pipes now installed between the Superheater Header(at the top) and the three Cylinders:
Inside the Smokebox, showing the 'Lemaitre' Blast Pipe fitted to the exhaust from the Cylinders, at the bottom of the Smokebox:
The underside of the Chimney, to which will be fitted the 'Petticoat Exhaust Ejector Ring', following the installation of the Superheater Elements:
Some of the fixings to the rear of the RHS Smoke Deflector:
The length of 50mm copper pipe, having been filled with sand, ready for bending:
Friday 27th April:- Today's task was, as a Team, to clean up 32 sets of fixing hangers for the Superheater Elements. These comprise a 1'' bolt (approx 12'' long), nut and spherical collar. These were quite heavily corroded with use and the first job was to get the seized nuts off the bolts! The nuts were heated up on one side and then removed (with a lot of effort) using a long handled socket wrench. The threads on the bolts then had to be cleaned with a 'die' and the nuts with a 'tap', using some cutting paste. A very time consuming task as you could only proceed about half a turn at a time and they were very long bolts and nuts!
- The installation of the Superheater Elements commenced in earnest today. By 'close of play', 16 (2 rows) out of the 32 elements, had been installed.
PW, heating up a seized nut on one of the Superheater Element hangers. Malcolm waits, ready to attack the nut with his socket wrench![Roger Hughes]:
Roger, cleaning the thread on one of the hanger bolts:
PW, cleaning the thread inside one of the hanger nuts:
Some of the cleaned bolts:
Job done! The 32 nut, bolt and collar units cleaned up and ready for fitting:
The Superheater Elements, awaiting installation:
An end view of a Superheater Element, showing the capped ends (these ends connect to the Steam Superheater Header) and the 'loose' fixing bracket:
The Superheater Elements are separated, ready for moving to the Locomotive:
The first Superheater Element is positioned in front of SKP, ready for lifting and installation:
The first Superheater Element, installed into the first of the 32 Superheater Flues:
A close up view of the first Superheater Element. This will be pushed into its final position to connect to the Superheater Header above. The 'loose' bracket will then be slid up, underneath the connections and fixed to the hangers via the centre fixing hole:
The first row of Superheater Elements are are in. Only 24 to go!:
Two pics of the (inverted) 'Petticoat Exhaust Ejector Ring'. Steel reinforcing brackets have now been added to the fixing holes
To finish with, just some 'general' photos:
34070 'Manston' in the foreground, on the right, with 34053 'Sir Keith Park' in the background, on the left:
The repairs to
'Manston' will soon be finished and this Locomotive will then leave the Works. After
'Sir Keith Park' departs,
257 Squadron' (currently sitting behind
'Manston') can then be relocated to where
'Sir Keith Park' is at the moment. Work can then start on the Major Overhaul of this Locomotive.
A close up of 'Manston', with the Engineering Workshop to the right:
A view of the Engineering Workshop:
Well, that's it. Job Done!
I hope that you have enjoyed these Reports over the past three and a half years or so.
If possible, I will post some 'final' pics, showing
'Battle of Britain Class' Locomotive
34053 'Sir Keith Park' departing Herston Works, Swanage for the
