Here are a few more photos showing some of the final work carried out on
'Sir Keith Park', at the Severn Valley Railway and her 'first fire'. Some of the pics are the same as those in the 'Link' included in Minty's Post of
Mon May 21, 2012. However, as a few of them are a 'follow on' from those included in my last Report (
Wed May 02, 2012) I thought that it would be a good idea to also include these here, together with some appropriate captions.
Here is Malcolm, inside the Smokebox, fitting the final row of the 32 Superheater Elements to the Superheater Header. [From my previous Report you may recognise (a) Top left: The large nuts of the Fixing Bolts for the Superheater Elements. (b) To the right: The supply pipe to the Blower Ring and (c) Behind Malcolm's left shoulder: The 50mm copper pipe (which I had to fill with sand) now formed to shape and installed. (This is the exhaust pipe, from the Brake Ejector in the Cab, to the Exhaust Ejector Ring below the Chimney)]:
The four rows of eight Superheater Elements, now all finally fixed to the Superheater Header:
Fixing the glass protectors to the two Water Level Gauges on the Boiler:
The New Tender of 'Sir Keith Park' receives its first load of coal (and water, of course):
The 'first fire' (in the completed Locomotive) is lit:
'Sir Keith Park' is moved back to the Engine Shed, after being weighed (over the built-in Weighing Scales at Bridgnorth) with its load of coal and water. (Approximate 'Design Weights' are: Locomotove 94 tons; Tender 42 Tons):
A view inside the Smokebox, following the first firing. (They've now made it all dirty!!!). Note the steam coming from the Blower Ring (around the Lemaitre Blast pipe) The Spark Arrestor has been (temporarily) removed:
My grateful thanks to
Southern Locomotives Ltd for the use of these pics and a special 'thank you' to Malcolm Garner (the owner of the photographs).
I am now
really looking forward to a successful 'Running In' period for the Locomotive and to then seeing
34053 'Sir Keith Park' in operation on Scheduled services at the
Severn Valley Railway.
