Identify the Aircraft
Re: Identify the Aircraft
Postby Saracenman » Sun May 10, 2009 5:03 pm
stab in the dark - the Murkin 737 based maritime patrol a/c?
Postby Mackrick » Sun May 10, 2009 8:08 pm
Here is the full photo before SB gets in ...
Postby Saracenman » Sun May 10, 2009 11:17 pm
well i must almost be right then - it's an early 737 judging by the engines - 737-100 or 200 series?
Postby Mackrick » Mon May 11, 2009 7:42 pm
come on I need the mark SM ...
The answers on the forum :ymdevil:
Postby Saracenman » Mon May 11, 2009 8:02 pm
stumped mate - the only 737-based a/c i can find any reference to is the 737-7ES - the 'AWACS' type 737 - but it looks absolutely NOTHING like that ~x(
Postby Mackrick » Mon May 11, 2009 8:16 pm
HINT HINT its on this forum somewhere SM
Postby Saracenman » Mon May 11, 2009 8:36 pm
well - i can't find a reference to it on this (or any other) forum to be honest - how about the 737 testbed a/c for the JSF/F35 programme?
Postby Mackrick » Mon May 11, 2009 9:02 pm
Postby Saracenman » Mon May 11, 2009 9:13 pm
ok ok - so it's the NT-43A radar testbed :D
at last!
Postby Mackrick » Tue May 12, 2009 12:11 pm
That was like pulling teeth SM
Your turn ..
Postby Saracenman » Tue May 12, 2009 2:09 pm
ooo - goody! :D
thanks Mackrick - yes, pulling teeth indeed :p
right then folks, what be this...
Postby Mackrick » Tue May 12, 2009 6:52 pm
How about one of these then SM
Its an M55 and if its wrong I'll regret this post.
An high-altitude aircraft with an high-aspect ratio U-2 like wing and twin tail booms. The obvious role is reconnaissance, but the M-17 was in fact designed to hunt reconnaissance balloons --- in the '50s and also in the '80s, the US used high-altitude balloons for recce missions over the USSR. The later M-55 or M-17RM was twin-engined and optimized for reconnaissance.
A two-seat version is under development and will enter service in 1997.
"Originally identified in 1982 by US recon- naissance satellites as the 'Ram-M' single-seat high-altitude reconnaissance aircraft, and later codenamed 'Mystic' by NATO, the twin-boom straight-wing jet, currently publicized as a high-altitude research aircraft able to carry around 1500kg (3,305 lb) of sensors, is now known to exist in two versions.
The first of two prototype aircraft, designated M-17 Stratosfera ('Mystic-A'), first flew in 1988 and are powered by a single 68.6kN ( 15,430 lb) thrust Rybinsk RD-36-51V turbojet developed from the Tu-144 SST powerplant. The M-55 Geofizika ('Mystic-B') , has two 49 kN (11,025 hp) thrust Perm/Solovyev PS-30-V12 turbojets mounted side-by- side behind a raised cockpit installed in a longer nose, together with a reduced span wing.
The role of the 'Mystic-B' is described as environmental sampling missions or high-altitude research and endurance in this role is claimed as over 4 hours loiter capability at 20000 m (65,600 ft).
A further variant of the M-55 is reported to be under development with wingroot mounted engines installed in a conventional fuselage carrying a sweptback tail unit . Two 'Mystic-A' prototypes, followed by two 'Mystic-B' and two pre-production 'Mystic-Bs' were flying by 1992.
Type: single-seat high-altitude research jet aircraft
Powerplant: two 49 kN (11,025 lb) Perm/Solovyev PS-30-V12 turbojets
Performance: maximum level speed 750 km/h (466 mph); endurance at 17000m (55,775 ft) 7 hours
Dimensions: span 40.7 m (123 ft 6 in); length 24.0 m (78 ft 9 in); height 4.8m (15 ft 9 in)"
Postby Saracenman » Tue May 12, 2009 7:12 pm
correct Mackrick - it is indeed a Myasishchev M-55, pictured at Farnborough of all places!
your go :)
Postby Mackrick » Tue May 12, 2009 7:41 pm
Try this one
Postby Mackrick » Fri May 15, 2009 8:34 pm
What no takers ?
Postby Saracenman » Fri May 15, 2009 8:35 pm
i did look, but all i could think of was Meteor - but I'm sure it's not that simple! :p
Postby Mackrick » Fri May 15, 2009 8:38 pm
Your right SM its not that simple maybe a neighbour of Dan4th could help
Postby Saracenman » Fri May 15, 2009 8:48 pm
Avro Canada CF-100?
Postby Dan4th » Fri May 15, 2009 8:53 pm
Sorry, I forgot about it, but I DO
think it's a "Canuck" from the
Frozen North.....
Postby Mackrick » Fri May 15, 2009 8:56 pm
Saracenman wrote:Avro Canada CF-100?
Manufacturer: Avro Canada: designed and built
Crew/Passengers: 2 crew (pilot/navigator) in ejection seats
Power Plant: Orenda Series 11 or 17 Turbojet
Performance: Max Speed: 525 kts (972.3 km/h) Cruising Speed: 400 kts (741 km/h) Service Ceiling: 41,000 ft (12,496 m) Range: 2000 nm (3,706 km)
Weights: Empty: 23,100 lbs(10,487 kg) Gross: 33,000 lbs (14,969 kg)
Dimensions: Span: 57 ft 6 in (16.31 m) Length: 54 ft 2 in (16.5 m) Height 14 ft 6 in (4.43 m) Wing Area: 526.6 sq ft (48.92 sq m)
Armament: 8 50-cal machine guns, provisions for Bombs, Rockets (unguided), Missiles
Cost: $660,000
Model No(s): Mk 1,2,3 A&B,4 A&B, 5 D&M, 6
correct SM your go ...
Postby Saracenman » Fri May 15, 2009 9:39 pm
blimey, thanks - i was expecting a few more rounds than that Mackrick! =))
ok, so what's this handsome little beastie?
Postby Mackrick » Sun May 17, 2009 5:07 pm
Any clues ?
Postby Saracenman » Sun May 17, 2009 5:09 pm
ok - designed before the war as a very easy to fly and safe a/c
it sold very well in the post war years too - even being made under licence by several companies :)
Postby Mackrick » Sun May 17, 2009 5:19 pm
American ?
Postby Saracenman » Sun May 17, 2009 5:33 pm
indeed - a Murkin machine it be :)
Users browsing this forum: No registered users and 50 guests
