Qantas Ground A380
Qantas Ground A380
Postby Mayfly » Thu Nov 04, 2010 8:23 am
I see 'something' fell off on it's way from Singapore to Sydney - the a/c flight had originated in the UK
http://www.bbc.co.uk/news/world-asia-pacific-11691197
Re: Qantos Ground A380
Postby Jigsaw » Thu Nov 04, 2010 8:51 am
Oops
Postby Xplumberlives » Thu Nov 04, 2010 9:31 am
Engine cowlings have lots of fasteners!
Postby Dickon » Thu Nov 04, 2010 9:24 pm
Down safe thank the Lord, but not good for the A380's/RR reputation...................
Dickon
Postby Sooty655 » Thu Nov 04, 2010 9:40 pm
RR now have ongoing problems with the 900 and 1000 models of the Trent. :-?
Postby Dougs » Thu Nov 04, 2010 9:51 pm
unfortunately looks like the same issue as sooty said both engines have had containment failure (the engines are supposed to fail safe and not throw debris out sideways)the trent 1000 failed in the test rig due to lack of oil on one of the bearings hope the failure on the 900 is not the same root cause or its going to be a very big problem,
the A380 has got holes in the wing from parts of the engine
Postby Xplumberlives » Thu Nov 04, 2010 10:27 pm
I thought the hole in the wing was caused by being hit by the cowling that came off rather than parts of the engine exploding!
Postby Sooty655 » Thu Nov 04, 2010 10:31 pm
Xplumberlives wrote:I thought the hole in the wing was caused by being hit by the cowling that came off rather than parts of the engine exploding!
No, it was definitely an uncontained engine failure. The pictures of the bits which landed on the Indonesian island include about 25% of a turbine disc. :(
Postby Xplumberlives » Thu Nov 04, 2010 10:36 pm
Oh then they do indeed have a problem to surmount!
Postby Mayfly » Thu Nov 04, 2010 10:37 pm
I know first thing [haven't taken any notice since] they assumed then an uncontained engine failure.
Postby Dougs » Fri Nov 05, 2010 8:52 am
the a380 fleet is being put back into service stating a design fault as the cause when i get back to work i shall find out if by that they mean the rear casing is not strong enough or the oil starvation fault is rearing its ugly head again.
Postby Xplumberlives » Fri Nov 05, 2010 8:55 am
Either way it's not particularly good is it?
Postby Mayfly » Fri Nov 05, 2010 9:15 am
I see they're saying this morning that it was a defect within the engine - as opposed to ingesting FOD etc!!
Singapore Airlines have inspected there fleet and lifted the ban on flying.
Postby Gully » Fri Nov 05, 2010 2:45 pm
Wonder how many carriers are switching their A380 orders to have the alternative Engine Alliance turbofans?!
Not a good advertisment for RR as it stands at the moment - the speculation is just as damaging as their actually culpability being established.
Postby Mayfly » Fri Nov 05, 2010 2:55 pm
proof if ever it was needed as to why they are so particular about 558s engines
Postby Dickon » Fri Nov 05, 2010 4:38 pm
Second Qantas jet in engine scare
A Qantas airline jumbo jet has been forced to return to Singapore because of an engine problem.
The Boeing 747-400 turned back shortly after take-off from Changi Airport, airline officials said.
It comes a day after a Qantas Airbus A380 was forced to make an emergency landing at the same airport after one of its engines exploded.
http://www.bbc.co.uk/news/world-asia-pacific-11702365
Dickon
Postby Xplumberlives » Fri Nov 05, 2010 5:08 pm
Oh dear! :-o
Postby Jigsaw » Fri Nov 05, 2010 9:48 pm
Xplumberlives wrote:Oh dear! :-o
Indeed. Strange.
Postby Mayfly » Fri Nov 05, 2010 9:58 pm
I believe I heard there were two with problems today both Qantas
Re: Qantas Ground A380
Postby Cluny » Fri Nov 05, 2010 10:48 pm
I think the finger has to point at there maintance and inspection procedures now with this second failliar with a different aircraft [747] and engine [P&W] :-?
Postby Dougs » Sun Nov 07, 2010 6:06 pm
The maintenance question is not the problem as the engine failure was un-contained which basically means that it could down the airplane and unfortunately it dose indeed look like a similar failure to the Trent 1000 engine as fitted to the dreamliner that was destroyed on the testbed at derby they both have the same core design which would also point to a serious problem.
the engine failure on the 747 was a pratt and whitney engine engine failures although rare are not unknown the biggie with this one was the fact that it was a 'new engine' with very few cycles and the fact that it was not contained within the engine nacelle. hope they find and fix the fault soon.
Postby Mayfly » Mon Nov 08, 2010 8:34 am
Qantas have said it will be another couple of days before they will be happy to let the A380s fly again
Edit: - latest news I just seen, Qantas say there are problems on 3 engines with 3 differant a/c :-o
Postby Sooty655 » Mon Nov 08, 2010 10:17 am
They are now reporting here that they have "found oil where oil shouldn't be" in three engines. :-?
Rolls Royce shares down again this morning. :(
Postby Gully » Mon Nov 08, 2010 2:44 pm
Postby Xplumberlives » Mon Nov 08, 2010 5:02 pm
Mayfly wrote:Qantas have said it will be another couple of days before they will be happy to let the A380s fly again
ADDED; just seen your spellchecker is broken! :p
