Static Plastic/Resin
Re: Static Plastic/Resin
Postby Xplumberlives » Wed May 12, 2010 8:46 pm
Tony, they were PINK, they won't look correct if you substitute brown versions!
Postby 350wedge » Wed May 12, 2010 9:12 pm
Xplumberlives wrote:Tony, they were PINK, they won't look correct if you substitute brown versions!
I think I'm going to give the 250 Humbrol option a go having read those links. Seems like its a pretty accurate match and I much prefer the matt finish to a glossy one. I can always go over it with a satin varnish if I want to adda little shine to it :D
Now I bet you cant get the 250 in a spray can, that would be too easy!
350wedge
Postby Old Rigger » Thu May 13, 2010 7:52 am
Postby Xplumberlives » Thu May 13, 2010 12:27 pm
63 SAND 150ml MATT Modellers Spray isn't really pink enough!
Postby Old Rigger » Thu May 13, 2010 3:46 pm
A link for a Tornado model build in desert pink:
http://tedtaylor.hobbyvista.com/28-mig-eater-tornado/page-28.html
A buccaneer build if you are interested, not desert pink:
http://tedtaylor.hobbyvista.com/34-airfix-buccaneer/page-34.html
Postby 350wedge » Thu May 13, 2010 8:17 pm
Thanks for those links... very interesting.
The Tornado is pretty much the colour I want so I think Humbrol 250 is the way to go. I do have a cheapy Revell airbrush that I can have a go with so I think I'll try that.
I went to get the kit on the way home but despite the store having one in stock on their computer they couldnt find it on the shelves. Hopefully they will have a look tomorrow and give me a call :D
350wedge
Postby 350wedge » Fri May 14, 2010 9:42 pm
In case anyone is interested there are some bargains here...
I just got the Tamyia Spitfire MKIX for £77, some other great bargains too but are going quickly !!
They did have the Revell 1/32 Typhoon for £25 but thats sold out now :(
http://www.themodeller.com/Plastic-Models-Sale
350wedge
Postby 350wedge » Tue May 18, 2010 9:14 pm
I've started work on the next project, managed to get a hold of an Airfix Buccaneer.
So far have done the main assembleys, some filler work was required but nothing too major. The fit of certain parts isnt too great but its acceptable for my purposes.
Will shortly be getting round attaching wings and then painting it in Humbrol 250, after that final assembly will take place...
350wedge
Postby Xplumberlives » Wed May 19, 2010 7:30 am
Is that the 1/72nd or the 1/48th scale Banana Jet?
Postby 350wedge » Wed May 19, 2010 9:24 am
Xplumberlives wrote:Is that the 1/72nd or the 1/48th scale Banana Jet?
Its the 1/72nd version hence the enormous lack of detail :))
350wedge
Postby Dougs » Wed May 19, 2010 12:52 pm
i have just purchased the Airfix typhoon and spitfire for my sons birthday dose anyone have any tips for a total plastic kit novice to make building the model more interesting and fun for an 8 year old?
Postby Xplumberlives » Wed May 19, 2010 1:51 pm
Dougs wrote:i have just purchased the Airfix typhoon and spitfire for my sons birthday dose anyone have any tips for a total plastic kit novice to make building the model more interesting and fun for an 8 year old?
Yes
STAND WELL BACK! =))
Postby Dougs » Wed May 19, 2010 8:40 pm
thanks xpl ;)
that will help no end! LOL
Postby Old Rigger » Thu May 20, 2010 10:29 am
Dougs: My only suggestions are:
Make sure you have a board to work on to protect any tables/floors you might wish to make the model on, I use an MDF sheet that sits on a foldaway picnic table.
Do it in stages with say a target time to finish that stage that ties in with school work (if any) bedtimes etc.
Read the instructions and decide what needs painting before you start gluing as it is a pain to mask canopies etc or get into corners if it is all stuck together, this goes with one above.
If your your son has the use of a computer, use the model making to help there as well, by searching for information on making models etc, if you follow some of the links I posted earlier you might find other people have made the same model , this then covers both activities.
Plan with your son on what he wants do do with it and where it will go when it is finished and maybe use that as a means of changing his room and if he would like to make more models in the future.
Now I have not had sons only daughters and I have only just started to re-kindle my model making interest after 40 odd years since I last made one, but I still think the above is a starter for ten as i am hooked and it keeps me off the streets. ;)
Postby Dougs » Thu May 20, 2010 2:48 pm
great thanks. i will get him to do an hour or so at a time that will keep him 'hungry' for more. he will get bored if i have him doing too much in one go :D
Postby Pujgnie » Thu May 20, 2010 7:44 pm
Beware of the 'over squeezing' of the glue... ;)
Fun it should be. Always start with a simple kit to build (ie less parts). Explain and identify all bits pre-gluing. Never comment on when they make inadvertantly make monumental errors in a haste to get it finished. Always let them paint it... it is a sense of achievement when they have painted it (no matter how wrong it may look :)) ). Transfers are a sharp learning curve, and may need parental guidance to oversee this final stage.
Once they have made one successfully, the confidence and interest will/should make them hungry for more. Slowly build up to a more difficult model. Airfix have 'Skill Levels' on the boxes as a guide.
Before long he will be building the biggies !!!
Postby Hihonyr8811 » Thu May 20, 2010 11:24 pm
Or do what I do and throw things at the glue until it vaguely reasembles the picture on the box =)) =))
Postby Xplumberlives » Fri May 21, 2010 7:45 am
Hihonyr8811 wrote:Or do what I do and throw things at the glue until it vaguely reasembles the picture on the box =)) =))
Often referred to as the HELEN 3D JIGSAW approach! ;)
Postby Dougs » Fri May 21, 2010 10:19 am
great tips thanks guys. Helen like your style :D :))
Postby 350wedge » Fri May 21, 2010 11:10 pm
350wedge
Postby Hihonyr8811 » Sat May 22, 2010 10:51 am
Yeah I could do with another one =))
Messed the first on up pretty spectacularly =)) =))
And the damn decals didn't stick X( ~x(
Postby 350wedge » Sat May 22, 2010 12:03 pm
Hihonyr8811 wrote:Yeah I could do with another one =))
Have you tried using microset or microsol on the decals ??
And I'm sure this wasnt on there yesterday... Vulcan gift set....
http://www.themodeller.com/products/Avr ... 50005.aspx
Btw postage costs from this place are brilliant, the postage on my Tamiya 1/32 Spitfire and Airfix Buccaneer only came to £2.99 !!! Was sent first class recorded delivery too.... Ordered it Thur night and had it Sat morning !!
350wedge
Postby Cluny » Sat May 22, 2010 10:30 pm
Sea Vixens been shelved for the time being due to constructional difficulties [ie gaps you can drive buses through when dry fitting the fuselage halves together] , very disapointed as the reviews i read said it was a good kit ~x( :((
Anyway , ive foolishly agreed to enter a competition on YouTube .
So heres a few pics of my first entry [allowed to enter 2 models] which ive been working on since wednesday ;)
1:72 Hasegawa Lightning F6 [brought from the LPG on the Q shed visit] .
As it is now .
Not sure if its going in Saudi , Kuwaiti or RAF markings yet .
Im not going to win obviously , its the taking part that counts ;)
Postby Xplumberlives » Sun May 23, 2010 9:58 am
Obviously!
Postby Gaz » Mon May 31, 2010 8:19 pm
I hope it's a better kit than my airfix bucc was!
I was happy with it in the end, but, sooooooo much filling and sanding to do ~x(
